66 327/350 Sidepipes - NCRS Discussion Boards
  • John L.
    • 409
    Need to replace the sidepipes (not the shields etc) on a 66 327-350 hp conv. This year engine needs a 2 inch exhaust pipe at the manifold. Does anyone out there make the correct pipes that will not get a deduction. Thanks in advance
  • Joe C.
    • August 31, 1999
    • 4598
    Re: 66 327/350 Sidepipes
    John,
    Shop Stainless Works for premium American-made 304 stainless steel headers and exhaust systems. Build your perfect setup with header kits, muffler kits, X-pipes, H-pipes, clamps, and mud boat mufflers. Designed for muscle car enthusiasts seeking unmatched performance and durability
    These manufacturers make reproduction sidepipes that look like originals on the outside, and probably will get a minimal deduction. All are made from carbon steel, if you like, with chromed exhaust tips, not SS. The innards are somewhat different than originals, and would not pass a PV. The perforated pipe used inside is thicker than originals, and the perforations are produced by a process that cannot reproduce the original shape and size of the perfs..............thus, a noticeably different exhaust note.
    Last time I looked at the driveline, I saw that Allens purchased an entire sh**load of original GM sidepipes. The ad says something like.........."we'll make them fit your Corvette if they do not". Meaning, I think, that BBC/SBC manifold sections will be interchanged as needed.
    Bring lots of $$$$$$$$$$$.
    If you decide on the reproductions, be sure to specify: "as original, 2 1/2" OD, carbon steel, with chromed exhaust tips". I would recommend these vendors in the order in which I listed them above, although all three are good, reputable businesses.
    Joe
    • John L.
      • 409
      Joe -- thanks - I will call Allens on Monday. they are basically 2.5 in pipes that reduce down to 2" to fit the ehaust manifolds. Maybe they have a set of GM pipes. The way the pipes reduce down and how they are welded at this location is where the problem arises.
