1985 build sheet - NCRS Discussion Boards
1985 build sheet
  • Marc N.
    • August 31, 1998
    • 97
    1985 build sheet
    HELP! did an 1985 vett come with a build sheet and if so, where is it normally found on the car.....thanks, marc
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 1985 build sheet
    Won't be to many more years and the 84 and 85's will be regular discussion topics with the NCRS. Anyway behind the drivers seat lift the compartment lid for the storage area and if it has not been removed, will be a large data sheet that is securely attached.
    • Lee
      Mark: There are two build sheets for your car. One on top of the tank and one in the left front frame rail near the wheel area. If you go to corvetteforum and do a search in the 84-96 forum there's a lot of info on the subject. I think you can also get a copy from Bowling Green. The address is at the forum. Lee
