1960 horn wiring at steering column - NCRS Discussion Boards
  • James Claxon
    Every time I think I'm almost finished with my six year restoration another little problem arises. the brown wire under the dash for the horns goes where? I personaly didn't remove that area in the beginning of the restoration. I didn't receive any wire to complete the connecton from the coupling on the end of the brown wire when I replaced the harness so I don't know what that connection should look like. thanks Jamie
  • Ed Jennings
    Re: 1960 horn wiring at steering column
    James, There should be a tan 20 ga wire with a rectangular white plastic connector that the horn wire plugs into. The connection is very near the point where the horn wire leaves the column. Tan 20 ga wire goes to the j box and then to the horn relay.
