Warning: Undefined array key 2157 in .../vb/library/content.php on line 3508 Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737 Warning: Undefined array key "online" in .../vb/library/content.php on line 3522 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165 Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182 Warning: Undefined array key "posts" in .../vb/api/user.php on line 183 Warning: Undefined array key "posts" in .../vb/api/user.php on line 189 Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480 Warning: Undefined array key "userid" in .../vb/api/user.php on line 204 Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246 Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342 Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594 Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610 69 SMall Block Fuel Pump - NCRS Discussion Boards
  • Erv M.
    • February 21, 2007
    • 445
    I was told that the Ac/Delco fuel pump has been discontinued which is hard to believe. Does anyone have the part number for this pump? I need to buy a new fuel pump and at least wanted to put an AC/Delco on since I do not have an original.
    Also doesn't the pump have a check valve in it to stop the fuel from draining from the carb creating a terrible cold start condition?
  • Dick W.
    • 10483
    Re: 69 SMall Block Fuel Pump
    AC is not in the manufacturing business anymore. You can buy a fuel pump in an AC box, with the correct numbers, but it will be most likely an Airtex manufactured pump. It will not have the AC cast into the body either
    Dick Whittington
    • Erv M.
      • February 21, 2007
      • 445
      Does it have the built in check valve that eliminates gas draining out of the carb?
      • Allen N.
        • Today
        Check Paragon to see if they still have any.
        http://www.corvette-paragon.com/cata...0-AF345743055A
        • Erv M.
          • February 21, 2007
          • 445
          I am having a problem of the gas siphoning out of the carb and creating terrible cold start conditions. Do these fuel pumps have a check valve in them to stop the back flow of gas? If not what does dtop gas from siphoning out of the carb through the fuel pump?
          • William C.
            • May 31, 1975
            • 6037
            Are you sure the problem is the fuel pump and not the carburetor? Q-jets are famous for leaking out of the plugs at the bottom of the carb center section and emptying the fuel bowl, taking lots of cranking to refill the fuel bowl before a car will start.
            Bill Clupper #618
            • Erv M.
              • February 21, 2007
              • 445
              I took the carb off the car. Put it on some sockets to lift the base from the bench top and filled it with gas, no leakage. Car was not sitting long enough, 12 hours, for the gas to evaporate.
              • Scott Marzahl
                Do you have the correct carb to intake manifold gaskets on. I saw your post over on the C2 forum and there was a recent discussion from Lars on the same type of issue. If your intake has the smiley face on it, couldn't this be a heat/percualtion/evaporation issue?
                  Then your problem is elsewhere...
                  If you've ever taken apart a rebuildable fuel pump, you'll see how it's constructed internally. There are two umbrella valves which allow fuel to flow in ONE direction only and they open/close with the oscillation of the pump's main diaphram.
                  For a fuel pump to 'leak' you either have a tear/rupture in the main diaphram (look OUT for raw gas to flow into the crank!), or you have a defective umbrella valves. If you want to verify the pump's integrity, simply remove it and 'try' to force fuel to flow in the reverse direction!
                  • Tom S.
                    • March 1, 2004
                    • 1087
                    Re: Then your problem is elsewhere...
                    Erv
                    I had the same problem with a 69 L-46. I pulled the carb, put it on the bench, no leaks. I changed gaskets no differance.I had the carb rebuilt, no differance. I pulled the carb again put in well plugs, no differance.I put on a NOS fuel pump, no differance.I sold the car! I never did figure it out! If you find out what the problem is please post it!Tom
                    • Erv M.
                      • February 21, 2007
                      • 445
                      Time for me to go back to square one and take a closer look at the carb. No plans on selling the car, ran great with the old carb on her. Just gotta give it some more love!!
                      • Dick W.
                        • 10483
                        Erv, maybe you bought Tom's car.
                        Dick Whittington
                        • Scott Marzahl
                          Hmmm, maybe Lars was just looking for an excuse to go to LA and drink a few beers with you.
                            Allen and Erv-----
                            1969 Corvettes with 350 cid engine did not originally use the AC type 40709 as seen in the Paragon catalog. The type 40709 was originally used for 1970-71 LT-1's and became the SERVICE fuel pump for 1968-69 Corvette small blocks MANY years ago when the original pump, AC type 40658, was discontinued through the GM parts system. Curiously, the type 40658 was available for many years thereafter through the Delco parts system. However, neither the 40709 or the 40658 are currently available through Delco or GM.
                            FUNCTIONALLY, the 40709 will work perfectly in replacement for any 68-69 small block. However, it is not correct, configuration-wise. It is VERY easy to discern a 40709 from a 40658. It could be done at a glance by any informed observer.
