How do you get the plug wires on a big block corvette with C-60, those two wires are hell to get to with the AC compressor and brackets in the way. Any tips would be appreciated thanks
plug wires C-3 big block
Re: plug wires C-3 big block
Follow the instrucions about going thru the inner fender. Also get you a pair of pliers designed to pull plug wires. DO NOT pull on the wire. You will destroy it. Pull on the boot only. Old Indian trick, use dielectric silicone inside the boots when reinstalling wires. Makes them a lot easier to remove next timeDick Whittington- Top
