72 LT1 twin belts - NCRS Discussion Boards
72 LT1 twin belts
  • John G.
    • April 19, 2007
    • 51
    72 LT1 twin belts
    I have seen photographs of 72 LT1 I am interested in purchasing and have noticed two belts on water pump pulley running across to alternator but I am told car does not have power steering and on other LT1 I (photo's only) I have not seen these dual belts. In tech info manual I have found a reference to dual groove power steering pulley on 454 engines but no other reference to these pulleys for other engines. Can anyone clarify this for me.
    thanks john
  • Dick W.
    • 10483
    Re: 72 LT1 twin belts
    Single belt alternator on LT 1
    Dick Whittington
    • Jerome E Pederson
      My '72 LT1 has a single belt to alternator
      • Roy V.
        • April 8, 2008
        • 296
        My 1972 LT-1 has 2 belts from the dual pulley attached to the Water pump housing. the inner groove(the one closest to the water pump) has a belt that goes to the altenator, the outer grove has a belt that goes to the A.I.R. pump.My car also has power steering and has a belt going from the power steering pump to the single pulley attached to the Crank.Hope that info helps because so many people ditched the A.I.R. system to free up a few horsepower.
          John-----
          NO PRODUCTION Corvette EVER ORIGINALLY used a dual groove alternator pulley---not a single one ever built.
          NO PRODUCTION Corvette small block also equipped with power steering EVER ORIGINALLY used a dual groove power steering pump pulley----not a single one ever built.
          ALL PRODUCTION Corvette big blocks also equipped with power steering used a dual groove power steering pump pulley---every one ever built.
          • John G.
            • April 19, 2007
            • 51
            Thank you all, I have looked at picture again and there is definitely two belts running over to the alternator. I hope to have this car inspected by Sal Carbone in the nex weeks so I am sure he will uncover mystery.
