Keen Corvette Parts lists a correct 65 4 quart oil pan w/ power steering for $269.
1. Does this oil pan require a baffle or can I use it as is? I ask because the main caps are all ready torqued and I hate mess with them.
2. I have a Melling 55-S3 oil pickup screen that is listed for a 327 corvette, would this be the correct screen for Keen's oil pan?
3. I have a oil pan that looks identical to the 65 4 quart oil pan w/ power steering but the dip stick tube is on the RH side vice the LH side. The drain plug is located at the rear centered. What year/car does this pan fit?
thanks, Dennis
thanks, Dennis
