c-2 knock off stuck - NCRS Discussion Boards
c-2 knock off stuck
  • James T.
    • May 31, 2006
    • 47
    c-2 knock off stuck
    The last of my knock offs won't co-operate. I have used up two lead hammers, used heat, used the knock off wrench with a handle, hammered in the opposite direction with nothing happening. Can anyone share a similar experience? What is next? Is there anyway to save the spinner? I would appreciate any advice. Thanks.
  • Mike McKown
    Re: c-2 knock off stuck
    Assuming somebody hasn't stuck a steel pin in the adaptor/spinner groove, proceed with the tire on the ground. Lay a block of wood (harder wood the better) on the spinner and hit it with a 5 pound steel sledge hammer. The more air in the tire, the better or you can put a floor jack under the A frame to keep the tire from absorbing the blow.
    I don't think there's any reason whatever to put KO's on this tight. Or even close to it.
