Does any one have any advice on the following: I have a 1964 365 hp car. Original engine never rebuilt. Original rebuild Carb. new fuel filter. I had compression check, valves tuned, distributor timed, Low mileage car. about 58k. runs good but wont idle low. I have to keep the idle at about 11000 rpm or she will die when sitting. But only when I run it a bit. If I go around the block a few times she runs fine. I put some of the store bought octane boost in and she seam to Idle a bit lower. I was going to try Wild Bills octane today! Could it be the vacuum advance, or fuel pump? Or any other trouble shooting areas?
Sam
Sam
