C2 Daytime Running Lights (DRLs)
  • Paul L.
    • November 1, 2002
    • 1414
    #1
    I hope safety subjects as well as originality issues are acceptable on this Technical Board. If not I would ask the moderators to delete this thread.
    I have driven Corvettes for more than 20 years and have always been concerned about their low frontal profile and visibility to oncoming traffic. The modern concept of daytime running lights (DRLs) was introduced/mandated in Canada about 1989. It seemed like an excellent visibility feature although there were naysayers. I adapted it to my former 1979 L-82 via Hella 1500 OptiLux lamps located behind the grilles.
    In 2003 I purchased my current 1967 and had the same concern. After some research I located an aftermarket DRL module suited to my car. Today was installation time. The unit uses the turn/flash filaments of the front 1157 bulbs. Rear bulbs are not affected or lit. The module is disengaged when parking lights are on as well as headlamps. It only operates when the ignition is on and headlamp switch off. It can be defeated if necessary by pulling a small underdash male/female connection originating from the untouched original harness. A more sophisticated approach would be a hidden toggle switch on the new power feed wire.
    An ignition-switched source of power (and fuse-protected) is needed. Wire surgery is limited to the front lamp pigtails. The main forward harness need not be touched. The module is small and easily hidden. I drove about 60 miles today and electrical performance is A/OK. The ammeter did not miss a beat.
    Thought I would share this with you. I have no doubt that my car's visibility to oncoming traffic is much improved.
  • Phil P.
    • April 1, 2006
    • 409
    name brand of unit ? thanks ! *NM*
    • Paul L.
      • November 1, 2002
      • 1414
      Re: name brand of unit ? thanks !
      Phil,
      I will assume this is permitted.
      WebElectric Products is the place to find the latest in car parts and electronic devices to help you personalize your automobile.
      • Rob A.
        • December 1, 1991
        • 50
        Re: C2 Daytime Running Lights (DRLs)
        Paul,
        I drive my black, '66 with the parking lights on for the same reason. I figure it might make my car a bit more visible at the right time someday.
        • Paul L.
          • November 1, 2002
          • 1414
          Rob,
          For those of us who drive these old cars, avoiding a "wrong" time is a must. Putting aside personal injury, even a minor accident can mean losing a driving season here in Canada what with the May-October driving window, non-availability of parts, lack of repair expertise, etc. If the DRLs serve to decrease risk of accident, and I believe they do, then it is $39 well spent.
          And I wish to reiterate that the only wiring cuts are to the front lamp pigtails. So pulling the system out if need be is a minor task. Going back to stock completely would mean new pigtails if the wiring cuts offend; not terribly expensive. I have a set of repro lamps on the car now with the originals in the basement so a swap is easy.
          And just a comment on those repros. The job took a couple of hours too long. Following the GM diagram the parking lamp wires are purple, the flasher wires are light and dark blue (left and right). With the repros, blue(s) is parking and purple is flasher!! Ouch.... After a bit of frustration, and time with a test light, we sorted that out. Fortunately we did not finalize (solder/tape) connections and wrap the wiring until the trial runs were complete.
          • Paul L.
            • November 1, 2002
            • 1414
            Two pics - One Parking and One DRL
            Parking.
            • Paul L.
              • November 1, 2002
              • 1414
              DRL.
