C2 Clutch Mechanism Binding - NCRS Discussion Boards
  • Brian K.
    • September 19, 2007
    • 174
    When depressing the clutch, the linkage "chatters" as though the crossbar is dry but it is greased well. I thought it may be the clutch diaphram fingers but I replaced the clutch & throwout. This happens slightly when cold and then when things get hot, it's acts up. I doubt it's the shaft under the dash because that does'nt get too hot. Could it be the ball socket bushing on the engine ball stud?
    If you depress the clutch quickly, this is less noticable but in normal use it is very annoying.
    Any help please?
    Brian
    66 Coupe
    66 Convertible
    2022 2LT Coupe
    67 Chevelle SS396
    67 XLCH HD Sportster
  • Mike G.
    • January 1, 1991
    • 418
    Re: C2 Clutch Mechanism Binding
    I would first disconnect the pushrod from the cross shaft and then operate the clutch pedal. At least you will eliminate pedal binding as the culprit.
    • Brian K.
      • 174
      It won't bind without a load on it.
      66 Coupe
      66 Convertible
      2022 2LT Coupe
      67 Chevelle SS396
      • Mike McKown
        Sounds to me like it is binding on the front bearing retainer. Look for worn fork, ball and/or bearing retainer or crud build-up on the retainer.
        I don't know whether you're supposed to do it or not but I've always lightly greased the bearing retainer bearing surface.
        I had one with your symptoms once. The bearing retainer was dry,worn and grooved. I worked it down with emery cloth, lubed it, put it back together and that was the last I heard of it.
