With the arrival of the long July 4th weekend, I decided to begin the task of replacing the clutch in my '67 L79 roadster. The car now has just over 50,000 original miles. The clutch was giving indications that it was in need of replacement primarily by slipping when tested in the normal manner. Also, the clutch did not "grab" in 1st gear until almost fully released-adjustments to the pedal free play did not seem to affect this characteristic.
My questions are as follows: How important is it to have the new assembly (pressure plate and disc) balanced along with the flywheel and were factory assemblies balanced? If this is important, can the balancing process be accomplished without the presence of any other mechanical comnponents? I've spoken with one local engine builder who tells me he cannot balance the flywheel and clutch assembly without the crankshaft. Is this true? Lastly, I've been told that there are several variations of throw-out bearings for Chevrolet engines. If this is correct, which is appropriate for this model and engine. Any input from those in the know would be greatly appreciated. Thanks.
Joe
#45420
Joe
#45420
