If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
Tried to install the new front wheel cylinders on my '57 chassis last night attempting to get it buttoned up and found the top portion of the cylinder was too thick and interfered with the piston retainer that is spot-welded to the backing plate. The cylinder would not quite fit flush to the backing plate and exhibited a distinct mark where the bracket hit it. I could grind the cylinder to fit but that bothers me. Has anyone experienced this concern with replacement cylinders? Is there a recommendation for an exact fit in any board members experience?
Don Yesacavage
This is a common problem with over the counter replacements from a local jobber. You might want to take them back and either rebuild the ones that were on the car or buy from a Corvette supplier that will guarentee that they will fit. Another option is to take your old ones to every parts store in your area untill you find one that matches correctly.
Thanks for the feedback. The original cylinders could probably be sleeved, they are pretty crusty. The vendor said "grind them to fit" I am not wild about that option. I have some local jobbers ordering cylinders to see if any of those fit correctly.
Don Yesacavage
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
