This is a long story but I will make it short. I recently purchased two new maintenance free batteries from Restoration Battery. When I installed them , they would not fit into the battery tray. I replaced two acid batteries purchased from same company which fit my reproduction battery tray. I called rtestoration and was told they should fit and that the tray was not the right size. Note I was told he never had anyone call with this problem but within five minutes or less into the discussion he had a soluton to the problem.
The reason for the posting is that I would like to know if anyone else has experienced this same problem and received the same response which basically was not acceptable. Also to alert NCRS members to be carefull , they will not be getting what is advertised for a cost of $250.
I purchased the batteries for a 62 corvette, thanks for reading, any comments will be appreciated.
