I removed the Midas muffler exhaust system from my '60 base engine car and proceeded to install the "correct" replacement parts obtained from a well-known aftermarket supplier. The passenger side went reasonably well and fit decently although there is only 1" clearance between the muffler and shock.
The drivers side is a different story- the oval muffler with welded front pipe cannot be rotated to the dimension of 1.6" as shown in ST12. In addition, the muffler to shock clearance is about 1/8".
I know these cars were not designed for maintainability but is it reasonable to presume that the exhaust system has to be disassembled whenever the shocks are replaced.
The parts vendor claims the parts were made and assembled on fixtures made from GM drawings.
Is there a fix or does one "live" with it?
