1967 rear end ID - NCRS Discussion Boards
1967 rear end ID
  • Paul Davies
    1967 rear end ID
    Re: 1967 rear end ID
    Paul -
    Can't explain the "LR" ratio code, but the "349" is the Julian day of the year (around mid-December), the "E" is an Eaton posi unit, and the "1" is first shift at Warren.
    • Harry Sadlock
      Check the 3871375 number is that the rear cover. The main carrier should be 3899143-N for a 67 and 3899143 for a 71 75. The reason I say 71 to 75 is that's when the LR cose was used.
      Harry
      • Harry Sadlock
        Paul, if the cast date is on the rear cover, then you have a 67 cover on a 71 to 75 carrier. Just a guess but this is what probably happened.
        Look at the date on the carrier and that will help you determine if it's a 71, 72, 73,.......
        Harry
