C2 Holley-Throttle Shaft Bushings - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3803
    Anyone know where I can find those teflon tape bushings for a 3810 (and other Holleys) throttle shafts.
    I know they replace them with brass bushings, but I just want to put the base plate back to its original configuration.
    Jerry Fuccillo
    #42179
    Jerry Fuccillo
  • Mike M.
    • May 31, 1974
    • 8365
    Re: C2 Holley-Throttle Shaft Bushings
    they're usually included in the holly carb master rebuild kit.mike
    • Clem Z.
      • January 1, 2006
      • 9427
      yes you are correct BUT holley no longer
      sells a masket rebuild kit for 3810. you can buy a master kit for some other model to get the teflon
      • Mike M.
        • May 31, 1974
        • 8365
        Re: yes you are correct BUT holley no longer
        gerald/clem: i can look and see if i have any of the bushings and if so, will send them to ya gerald.need your snail mail address. mike
        • Mike M.
          • May 31, 1974
          • 8365
          just found a bunch of the bushings. will send them to ya when i get your address. mike
