I have a 66 that I like to push outside of the garage before i start it, Also has Bias ply tires. The problem is it pushes very hard,Has a lot of drag The parking brake is set correctly and does not interfear, the wheel bearings are adjust correctly. Is this normall or does something else need to be adjusted or fixed.
C2 resistance
Re: C2 resistance
Should not be. Check your parking brake or your brake calipers. My 67 is the opposite, will roll on any slight grade even with the parking brake on.
But I need to redo the parking brake pads and assembly.
Jerry Fuccillo
#42179Jerry Fuccillo
1967 327/300 Convertible since 1968- Top
