I have a 67 427/390 (L36) that I have done quite a bit of restoration work to that I'm trying to dial in now that a lot of it is done. I am having some back fire issues now that I have gotten everything back together. A friend of mine that is relatively familiar with old motors and carberators suggested I re-torque the Intake Manifold which he feels may address the back fire issue. I removed the Intake Manifold, had it cleaned and repainted. I replaced the gaskets, restored the Distributor, had the Carb "show rebuilt", and did several other things at the same time. the car seems to run strong but it is back firing and the vaccuum seems low (11 inches of mercury). And when "cold", it does not want to Idle, but will once warmed up. (still back fires though)
We have checked and rechecked the timing, I think we are ok there.
What is the torque setting of the intake manifold bolts (I'll try re-torquing those)
Any other suggestions?
Thanks for any suggestions!
Steve
Steve
