C1 Rear Axle bearings and seals - NCRS Discussion Boards
  • Lee D.
    • September 30, 2000
    • 12
    I have developed a leak in my driver's side rear axle. Do I have to change the bearings in order to change the seal on the real axle, It's been a while since I pulled the axles and do not remember if the bearings are pressed into the rear housing assemby or to the rear axles.
    Thanks for your help.
  • Don Y.
    • July 31, 2000
    • 166
    Re: C1 Rear Axle bearings and seals
    Lee,
    The bearings are pressed onto the axles. There is a thin O-ring seal on the outer race and a paper gasket between the bearing retainer and the brake backing plate. Paragon lists a seal kit for 58 and newer C-1's that includes both.
    Don Yesacavage
    • James F.
      • December 1, 1985
      • 596
      Re: C1 Rear Axle bearings and seals-Lee
      Lee, The seal is an intergral part of the bearing assembly. A press is (generally required to remove the bearing and ring from the axle shaft. The press is also required to replace the bearing. The ST-12 is a decent workbook to work from. A good NAPA store should be able to come up with the correct bearing (not cheap). Hope this helps,
      • Terry D.
        • May 31, 1987
        • 2690
        Lee
        What year C1 are you working on? If the new bearing/seal still leaks, let me know as I had one that leaked after replacing bearings and seals twice. Pretty simple fix if Bubba has used a screw driver or other pry bar to try and get the bearing out.
        • Lee D.
          • 12
          It is a '59
          Lee
