69 seat rail to floor bolt finish - NCRS Discussion Boards
  • Greg L.
    • March 1, 2006
    • 2291
    What was the finish on these bolts? I was thinking black oxide or phosphate but then I saw a picture of a car not long ago and they were cad/zinc so I don't really know.
    I plan to do a bunch of plating next week so I'm just trying to get all the parts in the right boxes before hand.
    Thanks again.
    Greg Linton
    #45455
  • Jack H.
    • April 1, 1990
    • 9906
    Re: 69 seat rail to floor bolt finish
    If memory serves, they were typically black oxide to 'blend in' with the cosmetics of the seat rails...
      • 11608
      I'd say dark gray/black phosphate:
        • 43193
        Patrick and Greg----
        Yup! This is an original bolt and it's phosphate-coated just as it should be.
        • Greg L.
          • March 1, 2006
          • 2291
          You know, all you guys on this forum make this too easy! Thanks again.
            Black oxide and phosphate coatings are frequently confused, although they're distinctly different; black oxide was a very expensive finish for fasteners, and was almost never used for that reason. Don't know about C3's, but the only black oxide fasteners on a midyear are the five visible phillips oval-head cluster screws.
              • 11608
              Joe,
              If you want, I'll show you the bolt in person tomorrow.
              This particular one is the front outer driver's side, but the rest are the same.
              Patrick
