If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
In trying to calibrate/verify my temp gauge reading I have used a laser thermometer. The highest reading comes from the thermostare housing. My question is has anyone verified that this temp (assuming the laser gauge is acurate) is representive of the actual engine temp?
Jeff
You're after the engine coolant temp and not the temp of some particular casting that could be far enough removed from the coolant to climb somewhat above the coolant temp. Typically, the thermostat cover and the coolant temps will be pretty close to each other, but some shoot the bottom side of the upper rad hose since it's rubber and rather non-conductive with coolant flowing in a constant bath inside...
Considering the rather loose precision of the typical temp gauge system, you're close enough for a decent reading!
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
