Firewall To Cage Adhesive - NCRS Discussion Boards
  • Tommy F.
    • August 13, 2007
    • 97
    I'm just about to the point of re-mounting the front clip to the birdcage on my '74 coupe. I'm not sure what type of adhesive was used to seal the joint. It was not the standard issue bonding agent....black and pliable, almost like a roofing cement. I can't find any references in AIM, CC, or any of the other restoration manuals that I have. Any ideas would be appreciated.
    Tommy Flick
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: Firewall To Cage Adhesive
    Sealing and bonding are two different tasks and require two different products.
    On your 74, there is likely to be SMC body panels; use a Lord Fusor epoxy structural adhesive to bond the front clip to the bird cage. With the epoxy based adhesive, you can be SURE a bond will last if it is done properly.
    • Wayne W.
      • April 30, 1982
      • 3605
      I think he means the material between the bonding strip and the cage. This material is a non hardning structural type adhesive or sealer, put down first and then the bonding strip is riveted to the cage. The frontend is bonded to that. I use construction adhesive from the hardware store.
      • Chuck S.
        • April 1, 1992
        • 4668
        Oh...Like Liquid Nails Deck and Subfloor adhesive!?
        • Wayne W.
          • April 30, 1982
          • 3605
          You got it.
          • Tommy F.
            • August 13, 2007
            • 97
            Wayne,
            It is the riveted joint...so a non hardening construction adhesive should do it?
            ( I think Chuck is pulling my chain ).
            • Chuck S.
              • April 1, 1992
              • 4668
              Would I pull a Corvette bud's chain??!!
              Actually, it was Wayne that described the product...I just gave you a brand name (Liquid Nails) and Wayne agreed. Initially, I thought you were talking about bonding the body panels to the bonding strips that are riveted to the birdcage. For that, you would use the Fusor.
              The Liquid Nails helps to supplement the strength of the riveted joint while providing some slight flexibility in the joint. Liquid Nails is a very tough adhesive, but it does not handle UV light well...this will not be an issue in this application. Thanks to Wayne for a good idea.
