'60 aluminum heads questions - NCRS Discussion Boards
  • George W.
    • May 31, 2000
    • 543
    Hi all,
    I've read that the casting number for the '60 aluminum heads is 3772894, and that these heads have two pipe plug fittings on the exhaust side of each head.
    I have located a set of 3772895 aluminum heads dated 6 4 59 that do not have the pipe plugs.
    What are these? Early prototypes for the Vette, other GM product?
    george
    210 213 7004
    geopar@gvtc.com
  • GL Anderson
    Re: '60 aluminum heads questions
    Those (3772895) are the 60 aluminum heads that were cast at GIF or Grey Iron Foundry and intended for use in the production cars. I belive the other with the pipe plugs were the first cast in Italy and prototypes. I have a set of the ones you have located and they have no pipe plugs cast in. Do yours look like the the pic of mine? GL
