From what I can tell the early BB valve springs - the ones with a propensity to break -were a single spring with damper and used an O-ring seal - essentially the same setup as the SB.
The force data listed in the '67 AMA specs is 94-106 pounds @ 1.88", and 303-327 pounds @ 1.38". Using the center of these ranges, the rate works out to a whopping 430 pounds/inch. Geez, no wonder they broke a lot!
My '77 vintage Corvette P&A catalog lists "second design" components; 3970627 "spring unit" that must be used with 3964264 "cap unit" (retainer), and no seal is called out.
My 2006 GMPP catalog lists the above spring (described as dual) and retainer along with a 460527 seal kit, which I crossed at napaonline.com, and it appears to be a set of silicone rubber "umbrella" seals. Does the 264 "cap unit" differ from the 1st design, by having a provision for retaining the umbrella seals? The Chevrolet Power Manual (4th edition, Fig. 28 page 3-12), shows a photo of of production (which I assume are the second design) and racing spring and retainer, and the production retainer appears to be a two piece design with either a built in shield or seal retainer. The photo caption describes the spring as "valve spring and damper", but looking closely at the photo indicates a dual spring though it's tough to tell.
The 627 data in the GMPP catalog is seat force, 105 pounds @ 1.88" and a rate of only 267 pounds per inch, which seems low.
So can anyone verify the above or fill in the blanks and resolve the ambiguities?
The point is to restore a L-72, which may still have the early setup, to the later more reliable setup. No hot rod (or L-88/ZL-1) parts will be used - just second design production from GM or OE equivalent like Clevite or Sealed Power.
