Consider a restoration L-72 (less than 60K original miles - parked in a garage for over 30 years, engine currently seized) that will not be beat on, but the owner should not be concerned about buzzing it to 6500 when opportunities arise.
Assuming the rods pass Magnaflux inspection and better than OE bolts/nuts are installed, are they durable enough?
There's some cost tradeoff here, but durability is key. I haven't checked prices, but figure about 500 bucks for a set of Crower Sportsmans as a baseline upgrade.
Magnafluxing the rods might be "free" since a crank alone or a crank and eight rods may still be within the minimum "lot charge" of most shops.
Also resizing rods shortens their center to center rod length (which increases deck clearance and equal amount), which can be an additional method of managing as-built compression ratio.
Anyone know how much can be ground off the rod and cap for resizing - .010"? .020"? - before strength/durability are comprmised.
