89 Rear driveshaft U-Joint. - NCRS Discussion Boards
  • Richard S.
    • November 1, 1994
    • 809
    Is it possible to change out the rear driveshaft U-joint on an 89 with automatic transmission.... without having to remove the exhaust system....thanks for the help.
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 89 Rear driveshaft U-Joint.
    Rick my 85 and 96 Corvette service manuals say to remove the driveshaft remove the exhaust. I have speculated the idea if it would be feasable to unblolt the the driveshaft and unseat it and using a large C-clamp remove the u-joint. Not much space, however when I removed the u-joints from my 85's half shafts I was extremely surprised to find out how easy they were to remove from the aluminum shafts. If you find a way to change the rear u-joint without removing the exhaust let me know.
