Steering damper bushings.... - NCRS Discussion Boards
  • Jim V.
    • November 1, 1991
    • 587
    Any source for the pictured bushings used on the ends of C2 manual steering dampers ? I would like to use my original damper but the ends of the rubber bushings are deteriorated due to a little too aggressive cleanup. In lieu of bushing I was considering a purely cosmetic fix...aka black silicon...hmmmmmm
    Re: Steering damper bushings....
    Jim------
    Grommet GM #3735334 MAY work. I don't know for sure. These grommets are inexpensive, but they are supplied in a package of 20. So, unless you find a dealer that stocks them, you'll have to buy 20 to find out.
    • Jim V.
      • November 1, 1991
      • 587
      Joe...you deserve a raise...
      Thanks Joe....BTW...what is the application for that part?
        Re: Joe...you deserve a raise...
        Jim-----
        One application for the grommet I mentioned is for the rear shock lower mount.
