OK Fellas, I'm stumped: We have an early '56 fresh re-build, two fours, 097 cam, solid lifters, all built to specs. We have poor idling and performance as engine gets up to temperature, eventually sputtering out. Ignition is fine, fuel flow is fine, carbs are clean and functioning properly. Compression is strong and even in all cylinders, Avg. on first stroke of 120, and 160 on fourth strokes. No. 5 cylinder is the lone exception: 95 and 132. Nos.3 and 4 are 120,155-160 so I don't suspect a blown head gasket. Meanwhile No. 8 cylinder appears to not be firing at all and we have very poor vacuum: 9-10 inches at 900-1200 rpm. This should be at least 15 inches. The heat riser is fine and exhaust flow is fine. Visual inspection and pumping air into each combustion chamber have really not revealed a sticky valve in No. 8 or other cylinders, though that could be the case. Why else would No. 8 not be firing??
What do you think? Intake manifold crack on underside?( No leaks detected on top side and carbs ).Any ideas or other tests would be deeply appreciated as the car is "finished" and we hoped to put some miles on it this summer(it has about 800 miles on it since Summer of '98). Many thanks.
