Can anybody give me the proper location of ring gap on piston? My Sealed Power set for '61 230hp only shows views of oil ring. I need the location of first and second ring in relation to the oil ring. Thanks
installing piston rings
Re: installing piston rings
90 to 180 degree stagger will work Paul. It's not all that exacting a science when it comes to this, but you just don't want them staggered too close.
Make sure you feeler gauge the ring end gap in the cylinder bores as well if you haven't done so already.
Chuck- Top
Paul-----
An excerpt from the Chevrolet Overhaul Manual shows ring end gap positions:
Attached FilesIn Appreciation of John Hinckley- Top
Wayne-----
There's no way that they remain as originally set. However, I always set them as GM specifies, anyway. It's not that hard to do and, the way I figure it, it might not be beneficial but it can't be detrimental.In Appreciation of John Hinckley- Top
