I saw the post below about the possible MC internal failure. On Sunday my brake pedal also went to the floor, but there was still a tiny bit of brake action left. I just redid everything in the system (body off resto) with new calipers and brass sleeved master cylinder by WhitePost and all new lines. I had the brakes pressure bled a month ago (silicone fluid) and havent touched the car since. Is it more likely that the brakes need to be rebled or that the cylinder went bad?
thanks in advance!
Brandon
thanks in advance!
Brandon
