If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
I installed a reconditioned oil filter cannister that I got from David Crane about 8 years ago, and its leaking around the bolt. I seriously doubt he'll do anything about it. Can these be rebuilt? Is there a seal that can be installed under the bolt, and how is it done?
I installed a reconditioned canister from Paragon. It too had a leak at the bolt at first. I tightened it more... still leaked. I checked the torque requirement and went to that... still a small leak. Finally got out a bigger wrench and it stopped the leak. I believe that the first tightening needs to "set" the seal at the bolt. With the gasket at the rim absorbing some of the force it is difficult to get that set. Once this has been done then the "normal" tightness will suffice... I'll find out at the next filter change.
I'm sortof hesitant to tighten the bolt that much (althought I'm not really certain "how much" that is" for fear of pulling the threads. Maybe someone else can chime in who has some experience here? Wondering if a new seal on the bolt would help, or maybe I do need to torque it up....
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
