Apparently a previous owner removed the mounting brackets that should be up under the decklid on my 1968 Coupe. I have no way to mount the tray and am not sure how, or where, they should be mounted as the holes have been filled.
Can someone post or forward pictures via email of the mounting brackets with the tray removed so I can see them clearly. I need to know where (measurements?)and how (rivets or bolts) they are mounted.
Also, are they reproduced or do I have to find them used? Thnaks
GM
GM
