I have a new challenge with my 65 roadster. When driving I had an occasional cut out, seemed electrical not fuel. I thought it was a loose wire on the ignition switch becasue the plastic connecter has lost its little tab locks. I have tried about everywhere, and can't find a plastic connector to buy. I took the whole switch out, took the connector off removed and crimped each of the wire lugs carefully making sure that they would make good contact with the switch. After a few short runs I proclaimed victory, and thought that was the end of the story.
Tonight I headed off to a local cruise-in and of course the fun began just as I was pulling in, about a 15 mile ride. The car shut off a couple times, and was hard to start. I played with the wires reaching under the dash but I can't be sure that I had anything to do with when the car decided to start and run again. I got it home shut it off, and again it was hard to start but did eventually. I think that the problem may be elsewhere. Could it be the ignition switch itself?
Reading a post tonight about a bad set of points/condensor, I am really not sure where to start. Any and all suggestions about how to approach this are welcome, I really do not know where to look first.
Thank you all, as always,
George #36908
George #36908
