T10 IDENTIFICATION - NCRS Discussion Boards
T10 IDENTIFICATION
  • Bruce B.
    • May 31, 1996
    • 2930
    T10 IDENTIFICATION
    I JUST BOUGHT A BW T10 WITH THE FOLLOWING CASTING INFORMATION:
    Tailshaft,marked T10 7D, 7-18-03
    Main Case marked, T10D1,Characters in circles D, 24, 63
    Side cover date 7-15-63
    Stamped on spacer WJ43 2, does this translate as Warner gear Oct 1963, SHIFT 2?
    Was it used in Corvettes and/or passenger cars?
    Thanks.
  • Verne Frantz
    Sept.'63 Not orig Chevy anything
    Assembly date should be on rear of case, not inter bearing retainer. Assy date is Sept 4 '63, long after ANY T-10s were installed in ANY Chevy. Save the case. Throw everything else away.
    • Bruce B.
      • May 31, 1996
      • 2930
      Re: Sept.'63 Not orig Chevy anything
      The assembly date is on the upper rear drivers side of the main case. My error.
      • Verne Frantz
        In that "case", the trans must have been a service replacement. Only the case CAST date would fall into an actual assembly plant production time frame for any Chevy. Perhaps BOP or Studebaker used T-10s later in production???
        • William C.
          • May 31, 1975
          • 6037
          I've seen BOP and Studebaker examples, but all with cast iron cases. Trans would qualify as service replacement for Chevy. Way past time when Corvette went to Muncie in '63.
          Bill Clupper #618
