66 heater blower problems - NCRS Discussion Boards
  • Tim L.
    • January 1, 2005
    • 141
    Getting ready for judging at Illinois chapter meet next weekend and trying figure out why the heater blower does not work. Pulled the motor and birdcage out and hooked up to power suppy and it works. Fuse on panel is good. Any other suggestions for a quick fix without removing MANY parts?!?!? Any help is greatly appreciated.
    Thanks, Tim
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 66 heater blower problems
    Almost always the ground to the starter bolt.
      If that ground is OK (also grounds the wiper motor), could be the fan switch on the control cable or the resistor on the inner heater box.
      • Tim L.
        • January 1, 2005
        • 141
        Thanks for the responses. Pretty sure the ground is OK as I just had that area apart. How hard is it to get to the resister in the heater box?
        Thanks, Tim
          Tim -
          It's not real convenient - it's on the left side of the inner heater box, on the forward vertical face, facing the firewall - see your Assembly Manual, section 1Asm, sheets E5 and E6.
          • William C.
            • May 31, 1975
            • 6037
            Do you have te power feed hooked up to the heater switch?
            Bill Clupper #618
            • Tim L.
              • January 1, 2005
              • 141
              John,
              Looks like it's more involved than I have time for this week. Sounds like I need to pull the switch also to check it out. Guess I'll take the hit in Operations and add it to the list for winter projects!
              Thanks to all who responded.
              Tim
