I ordered an upper radiator hose for an L79 engine from Paragon. Other than the part# on it, it looks identical in shape to the 300 h.p. hose. It also appears about 1/2" too short to fit correctly. Any thoughts?
'66 L79 upper radiator hose
Re: '66 L79 upper radiator hose
Rob
What is the developed length of this hose?
I have the '66/300 HP hose also from Paragon (xxx7154). It is ~20" as measured along the blue stripe. The shape of both hoses should be very similar, but the L79 thermostat housing (xxxx369) differs somewhat in height and orientation from the base (xxxx660) outlet.- Top
