Speaking of C2 A/C Receivers / Driers - NCRS Discussion Boards
  • Wayne M.
    • March 1, 1980
    • 6414
    Jerome's post below jogged my brain cells on a question I've been meaning to ask. Here's an NOS drier / receiver that I bought from a GM dealer about 1982. Note the square boss to the left of the sight glass. I have another used drier with the same square boss.
    But the drier I got with my '65 (014xx, early Nov.64) does not have the square boss, but rather a continuation of the cylinder of the same diameter as the sight glass boss. The other side has a vertical round protrusion (you can see the bump just north of the "evap" stamping, and this is on all three examples I have, including the one that came with my car.
    Also; is this black plastic plug of the type expected to be present according to the '65 TIM&JG ? (5th ed., pg 127, bottom)
    So, how does this "square boss" judge ? Is it immediately flagged as a replacement ?
  • Peter L.
    • May 31, 1983
    • 1930
    Re: Speaking of C2 A/C Receivers / Driers
    Wayne - A feature I have also noted but don't know if there's a correlation. But here's a couple of data points for you. The orignal AC driers on my late 66 C60 Chevelle has no boss, where as my early 67 C60 Corvette has the boss. Pete
    • William C.
      • May 31, 1975
      • 6037
      Black plug should be in place for judging.
      Bill Clupper #618
