68 fan shroud extension - NCRS Discussion Boards
  • Mark Stocki
    Were the fan shroud extensions only installed on cars with A/C? Would it be on a 427 non-A/C car?
  • Anthony S.
    • April 3, 2008
    • 183
    Re: 68 fan shroud extension
    Mark,
    My 327/300 with A/C has the large metal "barrel" fan shroud if that helps narrow it down a bit.
    Anthony
    • Terry B.
      • August 31, 1999
      • 607
      Mark,
      Your 427, with a copper radiator, should have the shroud extention regardless of the AC option. On some very early '68 cars with copper radiators, metal shrouds were used. Thereafter, copper radiators shrouds were unpainted black fiberglass reinforced plastic with the extenstion attached. Hope this helps!
      Terry Buchanan
      Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
      Corvettes Owned:
      1977 Coupe
      1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
      2003 Electron Blue Coupe
      2019 Torch Red Grand Sport Coupe
      • Jim T.
        • March 1, 1993
        • 5351
        Anthony does your 68 with C60 have its original radiator? If it does is it aluminum and also have the aluminum surge/fill tank?
        • Anthony S.
          • April 3, 2008
          • 183
          Jim,
          It is a Harrison radiator, but probably not the original. It has the fill cap on the radiator, with no expansion tank.
          It was just recored with a I believe a replacement copper core.
          Anthony
          • Wayne W.
            • April 30, 1982
            • 3605
            Original late `68 SB with AC.
            • Bryan K. Montford
              What engine/transmission option is that? My Nov. 67 a/c car has a metal shroud.
              Do you have a pic of the idle solenoid set-up?
              Bryan
              • Jim T.
                • March 1, 1993
                • 5351
                Thanks for posting the picture Wayne. Now I know of the differences in the metal shrouds for the 68 327 with/without air and the type of radiators.
                  Pix of all three versions of idle stop solenoid...
                  are shown in MF Dobbin's 1968-72 Corvette Fact Book. The three versions are: (1) Qjet equipped, (2) Holley tri-power equipped, and (3) Holley 4-Bbl equipped (L88). Put your support library to work!
                  • Bryan K. Montford
                    Re: Pix of all three versions of idle stop solenoi
                    Jack,
                    Can you buy the book off this website? If you can, I sure can't find it.
                    Bryan
                    • Dick W.
                      • 10483
                      It may not be on the website, but they do carry it in the store. Give them a call or email and I am sure Gary or Eric will take good care of you.
                      Dick Whittington
                      • Bryan K. Montford
                        Thanks Dick! *NM*
