C2 Carpet Installation - NCRS Discussion Boards
  • Donald T.
    • September 30, 2002
    • 1319
    Hi guys. A quick question on carpet installation. The AIM states that the front edge of the carpet tucks under the dash mat. My dimmer switch wire harness is on top of the dash matt, and then the carpet would be installed over the wire harness. So how can the front edge of the carpet tuck under the dash mat when the dimmer switch wire harness is in the way?
    Thanks!
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: C2 Carpet Installation
    On a 67 the dimmer switch wiring runs behind the firewall insulation (not visible) and the carpet tucks under the insulation edge.
    To install the wiring correctly just disconnect at the switch and tuck it thru the access hole in the insulation and then reconnect
    • Donald T.
      • 1319
      Thanks Steve. Mine must have been improperly installed at some point in the past. That makes more sense.
      Thanks!
