T-10 Transmission - NCRS Discussion Boards
T-10 Transmission
  • Ray C.
    • June 30, 2001
    • 1132
    T-10 Transmission
    Could some one please decipher the following transmission codes and what would be the application?
    The date code is either 0 or D-30-00 or 03
    Thanks for any help!
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
    Re: T-10 Transmission
    Ray------
    It looks to me like it might be "D.30.8", with the "8 laying down". If so, I expect that it's April 30, 1958.
    • Ray C.
      • June 30, 2001
      • 1132
      Thanks! Joe
      I would have never looked at it as an 8 on it's side.
      Would you happen to know what the Q-2 signifies and is the lone "2" for second shift?
      Ray.
      Ray Carney
        Ray------
        The other characters I do not have any knowledge of. I expect that they are some sort of foundry marks used by whatever foundry cast-up these cases for Borg-Warner. It's possible Borg-Warner had their own in-house foundry. Either way, though, I'll bet the meaning of these marks has been "lost in antiquity".
        The "8" in the date code looks like the character is of a larger font size than the rest of the characters. That may be why it had to be inserted "laying down". It's also possible that the "laying down" character had some other significance.
        • Ray C.
          • June 30, 2001
          • 1132
          Thanks! Ray
          Ray Carney
          • Loren L.
            • April 30, 1976
            • 4104
            Where is this date? Is it a casting date
            or an assembly stamping? All T-10 "assembly" dates begin with a "W".
            • Loren Smith
              Colvin's book says T10-1B cases were only cast from June 59 to January 61, which would eliminate a 1958 date as a possibility. My T10-1 case for my 59 has a cast date of 9-24, with no year. I don't know whether T10-1B cases had a year code as part of the casting date, but if they did, maybe you are looking at April 30, 1960, which was a Saturday.
              • Loren Smith
                You should have an assembly stamping next to where the sidecover bolts on like "WF1002", which would be June 10, 1960, 2nd shift, for example.
                • Ray C.
                  • June 30, 2001
                  • 1132
                  Thanks! Loren
                  WG 2932
                  Would this code mean: July 29, 63 2cd shift, and if so what might be the application.
                  Ray
                  Ray Carney
                  • Richard H.
                    • March 1, 1985
                    • 241
                    Ray,
                    I would concur with your reading of the assembly date. Based upon the casting and assembly dates for 1963, I do not believe that it is possible to differentiate Corvette T-10's from other makes . I could be wrong about this latter issue though. Richard
                    • Loren Smith
                      TMJG says cast iron cases were only used up to VIN 2400 in 1961, with the aluminum cases thereafter. Could this be a passenger car T10 assembled in 1963?
                      • Loren Smith
                        Check out ebay auction no. 260151970398 for a 62 T10 with a T10-1B cast iron case and a casting date of E.9.62 for a good comparison to yours:
