My early 1963 300 HP has a Carter AFB 3461S carb. I’ve been having an inconsistent problem with it flooding over. It will feel like the car is running out of gas, but in reality enough fuel is dumping in to the carb to kill the motor instantly unless the RPMs are kept up. Upon inspection, gas can been seen dripping out the sides of the carb on to the manifold. It appears that the needles are getting stuck “out” allowing fuel to pour in to the bowl regardless of the position of the floats. The easy remedy involves removing the air cleaner and tapping on the top/rear of the carb with a hammer to try to free up the needles. If this doesn’t work, the top of the carb must be disassembled to gain access to the needles so they can be manipulated.
The needles, seats, floats and float “axles” (for lack of a proper term) have all been replaced, some more than once. The float levels have been adjusted and I believe they’re in the right place. The fuel pump has been replaced too, thinking that perhaps there was too much fuel pressure. I can’t find a pattern as to what triggers the flooding, although it is more likely to happen during heavy throttle. Once it’s been “fixed”, there are no worries until the next random time that the needles get stuck.
Any help that can be suggested would be appreciated, or recommendations on who would be the right person to speak to / work with. Possibly unrelated note: there is also some (occasionally bad) hesitation when starting out in first. The engine will lug as load comes on. Stuff the clutch, try again, and it will get moving. I’ve got the PCV hose partially restricted and this seems to help somewhat.
Seth
Seth
