1960 Clutch Return Spring - NCRS Discussion Boards
  • Peter K.
    • January 1, 1999
    • 117
    What is the proper procedure for installing the clutch return spring on my 1960. This is the heavy spring that goes from the frame to the bracket which is attahed to the cross shaft. Thanks in advance.
  • Don H.
    • December 1, 1981
    • 1482
    Re: 1960 Clutch Return Spring
    Unless you are having the car judged, I would suggest you leave it off. I have only used one for maybe a month in over 30 years of driving my 60. Don H.
    • Leo G.
      • August 31, 1987
      • 116
      There is an excellent article in the Restorer, Volume 14, Number 1 written by Joe Calcagno. It not only tells you how but also gives detailed information on how to make a installation tool that works well. I just replaced my clutch cross shaft in the 61 and the tool made life very safe and easy.
      • Jim D.
        • 2882
        Assemble everything but only use the lower bolt for the bracket that attaches to the cross shaft. Then use a wrench or bar to rotate the bracket until the upper holes line up and install that bolt. Takes longer to explain than to do it. I've been doing it for 40 years and it only takes a couple mins. to install the whole set-up.
        • Dennis C.
          NCRS Past Judging Chairman
          • January 1, 1984
          • 2409
          Agree w/Jim... My preference is a large...
          ...(12") cresent wrench to rotate the cross shaft forward against the force of the "garage door" spring. Do you need this counterbalance spring??? Maybe not, but I just follow the General's instructions & install it anyway
          • Tom B.
            • March 1, 1978
            • 720
            That does sound easy. Mines been laying in a box since the summer of 1971. Maybe I'll attempt to re-install it now.
            Tom
