Vent Wing Weather Stripping
  • Terry Hitch
    #1
    Hi Group, When replacing the Weather Stripping around the Wing Vent there must be an easy way to remove the vent. Does, the shaft piece unscrew on the bottom of the wing, the hinge looks to be rivited in side and out side. Any hints, Thank you
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Vent Wing Weather Stripping
    you will need to remove the vent window assy from door. this was covered in back issue of Restorer. the vent window frame will allow enough flex of the rubber to push down on the vent window frame to remove. reverse for install.
