Hi all, I am trying to remove my rear brake rotors so that I can them turned as part of a complete suspension/brake job. I drilled out the rivets with a large enough diameter drill bit to get the heads off, but leave some material in so I don't drill into the rotor itself by accident. I assume that an axle puller is required to pull the rotor off the hub. I borrowed one from AutoZone but it is too small. Before I go back down there and try to find another one I wanted to see if there was some trick that I was missing here... Can someone enlighten me? Should I just use a larger drill bit and not worry about the rotor material? Thanks! Jeff
Jeff's '74 Corvette Restoration Project
