I'm getting my 75 convertible ready for the Northwest Regional and in the process I am tightening various bolts and nuts per factory specifications. The problem I've run into is the inability to place a socket over some of the nuts/bolts because of space constraints. However I am able to get a clawfoot into the area and onto the nut/bolts. Will the torque wrench deliver the same torque to the nut/bolt using the clawfoot? I ask because the clawfoot is offset compared to the center of the socket, which is identical to the center of the nut/bolt.
In case I'm misusing the term "Clawfoot" I will describe it. It is tool similar in shape and size to the open end of an open end wrench. It attaches to a standard 3/8 drive ratchet.
