Need '62 300 HP spark advance map data
    • 15229
    If anyone has a ST-12 or '62 AMA specs handy can you give me the centrifugal and vacuum advance data for the '62 327/300?
  • Rob Dame
    Re: Need '62 300 HP spark advance map data
    From the ST-12 for the 1110984 dist
    Centrifugal
    Start 0 - 2 at 425 RPMs
    Intermediate 8 - 10 at 1600
    Max 11 - 13 at 2300
    Vacuum unit # 1116201
    Inches of hg to start 7 - 9
    Inches of hg full advance 15 -16
    Max dist advance 7.5
      • 15229
      Thanks. I am assuming the centrifugal data is disributor degrees and RPM, so nominal at the crankshaft:
      2 @850
      18 @ 3200
      24 @ 4600
      This appears to be the same as '63 as is the 201 VAC.
      • William C.
        • June 1, 1975
        • 6037
        That is correct.
        Bill Clupper #618
