I've been looking at my body mounts and the rubber looks rough. At present the car is being restored and I'd like to replace the body mounts before I install the bumpers etc.
The car is a B/B coupe,4 speed. Any special process that needs to be done or you might suggest I'd appreciate. I plan on having the car in the air on jacks to do the work (the old way) will use liquid blaster on bolts/nuts and let set overnight on each mount,loosen each mount,then remove using a small floor jack with a 6"x1"x3' board to just allow me clearance to do each change out.
Any special set process of removal, like front side to side or front left after right etc. Any input will be appreciated. I'm aware of the shims and will keep a close eye for them. After I finish I'll install my bumpers. By the way I ordered some bumper gaskets called "paint savers" from Dr.Rebuild to install between the body and the bumpers to save on wear. I don't care about any points just the car.Thanks,grr#33570
