Thanks for the responses to my last post re:1965 Muncie of June 12th. Now that I have the trans apart, I believe I MAY have more problems (oh great-I love a challenge, and so does my wallet!).
First, some background. Before taking the car out of service, the only problem I had with the trans was that it would jump out of second gear. All other gears were fine. No noise, gear clash, etc. It was SLIGHTLY hard to shift into all gears, which I attributed to worn synchros and a bad clutch. The clutch was worn past the rivets, so a new one will be going in later. The flywheel was refaced with a minimal cut of about .010", and had minor surface cracks/runout, which all cleaned up well. The ball stud in the bellhousing was the wrong type (too short) and that was replaced with the correct part.
Inside the trans. I found all synchros (except first gear) to be moderately worn. First synchro is like new. Here's the problem(?) : 1&2 synchro/hub/sleeve assembly are the are the new type (shouldered ring-narrow hub). 3&4 synchro/hub/sleeve assembly are the old type (no shoulder on ring-wide hub).The rebuild kit (late 1965-1970) came with the new type synchro rings. All the gears on the mainshaft had minimal end play, EXCEPT SECOND GEAR (meas. @ .028"). Also,the 3&4 hub and sleeve (old type) show moderate wear on the splines. The 1&2 hub and sleeve (new type) are like new. All 6 clutch keys are the same-on the 1&2 ring, they are the same width as the hub, and on the 3&4 ring, they are about 1/8" shorter than the hub.
QUESTIONS:
1. Is the .028" end play on second gear within normal range? 2. What type of synchros are correct for this trans (May 1965). 3. Would the moderate wear on the 3&4 hub and sleeve be grounds for replacement(there was no problem with 3rd and 4th gears). 4. Should the clutch keys reach the ends of the hubs, or should they measure about 1/16" short of each end.
Remember, the car was jumping out of second.
QUESTIONS:
