Original Alternator Belt? - NCRS Discussion Boards
  • Mario Boni
    I have replaced the alternator belt on my 1967-L79 coupe for the sake of safety and reliability. I believe it to be the original. Is there any way to tell? I know some original parts, like air filter elements, are highly coveted. How about things like original alternator belts?
    Mario
    Re: Original Alternator Belt?
    Mario-----
    Is there a GM part number embossed on the belt? If so, what is it? If the part number is printed in white, you need look no further; it's then NOT an original belt.
    • Mario Boni
      Joe there is an embossed GM followed by an embossed 3861946 as well as other markings and numbers embossed into the belt. I can check what the markings are when I get home from work. The markings are definitely not stamped on the belt in paint or ink.
        mario-----
        It sounds like it could very well be an original belt. Of course, it could also be an early replacement using the same belt as was used in PRODUCTION or, even, a reproduction belt.
